atg87tc
Aug 2004
evansville, IN, USA
i just replaced the door speakers on my 87tc with 6 1/2 inch pioneers. this required a few extra holes to be drilled because i guess the stock speaker werent 6 1/2's, even though that is what i was told at circuit city. before i go and ask them again, i was wondering if anyone here could tell me what size the rear speaker and dash speakers are. i dont trust what circuit city says anymore. thank you
87tc-k&n, glasspacks, 5speed
88tc-5.0 conversion. 450rwhp [email protected] 122
99mustang cobra-stock
Keith Pellerito
Aug 2004
Fenton, MI, U.S.
THE FACTORY SIZE IN THE BACK ARE 5x7, PUT 6x9s IN, THEY WILL SOUND MUCH BETTER. THE FRONTS WILL FIT 4 INCH, PUT EITHER 3 1/2s OR 4s DEPENDING UPON YOUR PREFERENCE.
yeah it is fast, just a little slow getting back to the garage!🚓
atg87tc
Aug 2004
evansville, IN, USA
the rears are 5X7, so how difficult is it to fit 6X9's back there? do i have to cut stuff out, or jus drill a few new holes?
Walsted
Fort Worth, TX
I had always thought dash were 3 1/2, door were 6 1/2, and rear were 6x8, all with proprietary wire connectors, meaning that you couldn't just remove the old one and insert a new after market speaker without an adapter or wire cutting. I could be wrong, though.
Keith Pellerito
Aug 2004
Fenton, MI, U.S.
You do not have to cut anything, just push the flares up that hold your current speakers in place and just screw the 6x9s in--very easy. Do not worry about the wiring, all you have to do is if you have premium sound back there, you will have 4 wires going into the plug that goes into your factory harness, you eed only 2 of those wires, just choose which ones you want--just make sure you get one with a stripe and one without--if you do not get it, let me know and I will go out to my car tomorrow and look which colors I have hooked up on mine--I remember playing with the wires a couple different times to get what sounds best--let me know if you dont get it.
atg87tc
Aug 2004
evansville, IN, USA
ok thanks, when i hooked up the door speaker, there were 4 wires and they all were hooked into a clip. i cut the clip off, and just twisted the two wires with the stripe together, and the 2 wires without the stripe. they are working fine now. now with the 6x9's i wont be able to keep the stock speaker grille will i? its ok, im just wondering if i need to buy speakers with a grill
Keith Pellerito
Aug 2004
Fenton, MI, U.S.
You do not need to worry about losing the grill, it should go underneath the existing one since it is inside the trunk. And I actually do think that I did my wires the same way--
PetzJC
Feb 2004
California, MD
If you do not like/trust Circuit City (I don't), go through Crutchfield out of Charlottesville, VA. They are awesome. They even include speaker connector adapters for whatever car the speakers are going into....no cutting/soldering or anything. Their number is: (888)955-6000, or www.crutchfield.com
88 Silver T/C, original owner, 256,000 miles.
Loaded with everything except leather & auto trans.
K&N, Gillis, SVO roller #1, big SS valves, ported intake, head, & exhaust.
Bottom end & turbo original/untouched.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16's.
Former owner of 88 Silver T/C, loaded (except leather & A/T), original owner, 294,815 miles!!!
K&N, Gillis(18 psi), SVO roller #1, big SS valves, ported intake, head, & exhaust.
Short block & turbo original/untouched, spec-II/III clutch combo.
atg87tc
Aug 2004
evansville, IN, USA
ok thanks, now are there any suggestions on speakers? i put some pioneers in the door, they were $50 a pair. these speakers are ok, but id kinda like to put infinity's in the back. are there any other speakers that someone would suggest?
Lx-tasy
Jun 2004
Jacksonville, FL
Audiobahns are really good speakers.They are pretty cheap too.Just watch what series ya get.
Chris
