pressure hose
mhopper220 Offline
I have a huge power steerig leek.most of my pressure hoses have play were the nut is tightend to the p.s. pump and what i think is the steering gear. much thanks mike
Michael Hopper
They are supposed to have play, and be able to swivel around. They are basically sealed with an O ring. If the O ring seal goes bad, they can and will leak, but the "looseness" itself doeant have anything to do with the leak.
mhopper220 Offline
Thanks jeff!!
Michael Hopper
ipsd Offline
Make sure you get the right o-rings if you get regualar ones they might not hold up to long. I say if you can't find them a the parts store have them look in there hydualic hose stuff for some o-rings that are the same size. Either that or head over to a place that make hydrulic hoses and look at there o-rings for hydualics. I know the parts store I work at we makes hydualic hoses and keep lots of those o-rings in stock.
84 T/c, 88 intake,I/C, injectors, hood, PC1 ecu, E6 manifold, Brown Tops, K$N open element, BPV. Way pay to run 8 cylinders when 4 plus a turbo will get you there quicker.
mhopper220, please contact me, pmdunham at centurytel.net
