gtbird
Dec 2001
Hope, RI 02831
If somebody has the schematics for an 88 T/C could you please find the location/wire colors for wire 37 and 904. They are supposed to be near the ignition coil and/or EEC Test Connector. I think wire 904 is circuit 837C yellow/black?
Wire 37 is battery to load and is yellow
Wire 904 is the coil or (accy) terminal of the ignition switch to alternator regulator (ign term). It light green w/ red stripe
"The nice thing about each new day is nobody ever used it before" Barnaby Jones
gtbird
Dec 2001
Hope, RI 02831
Pete: Where can I locate these two wires? Thanks,
Rick
The yellow wire (937) connects the fuse links G (14 ga, green), F (16ga, black) to Fuse #1 (15amp) to the igniition switch. The fuse links G & F are near the starter relay. The fuse panel is under the dash on the left of the steering column. The ignition switch is in the steering colume
904: there is a R/LG and a BR/PK wires from the ignition switch that goes to fuse link H (20 ga, blue, splice 264, near the starter relay.) 904 (LG/R) comes out of that fuse link and goes to the alternator.
[This message has been edited by Pete D (edited 05-25-2002).]
