Alaskanzeus
May 2002
Anchorage, AK USA
The debate came out today of cork or rubber valve cover gaskets, and which was better on the TC. I read the forums didnt see anything on this subject. Need to get one soon, before my drive way becomes full of kitty litter.
GaryS#2
May 2001
B.C. Canada
Definately 1 vote for rubber here.
Grocery Getter/Rice Cooker.
GT350R
Cleveland
Cork should not even be used for wine bottles!
Not only is it impossible to get the cork ones to seal, the next time you need to pull the valve cover , it is a mess and you will always get some crud in the oilling area. Thats bad.
natmac3
Aberdeen, MD
I 3rd the rubber...
1987tc
Hybridbird
Rockford IL
RUBBA!!
Too much fun, what's that mean?That's like too much boost,there's no such thing.
"Finch....get the f*ck away from that Ficus......that's a jizz-free Ficus!"
My Money Pit
Apr 2002
Seattle, WA
Got a new rubber and silicone one today...works great so far.
Josh
88 T/C 169,000 mi.
She's old, She's slow, She leaks oil, She runs hot, She grinds gears and she just pulled a U-Haul from Florida to Seattle, WA, happily, and I drive her every day.
UPDATE:
Single 2.5" Catback thru Superflow
Almost all new wiring
New ABS (newly rebuilt)
Secondary Cooling Fan now manually switched "in-car"
All new seals, gaskets, hoses, and all other "basics"
FULL BOOST (finally)
Next Week...
Off to Nashville
Walsted
Fort Worth, TX
I use this rubber on both, and have no problems with leaks from the valve cover. $15.10 from Autozone, $19 from O'Reilly.
Mike Walsted - NATO member
1986 5-speed TurboCoupe and 1985 5-speed XR7
shiftless
Dec 2001
Gadsden, AL
unless you *like* spending hours scraping shit off your valve cover and mating surface after you pull it off, get the rubber one.
methos
May 2001
Cynthiana, KY
Another vote for rubber... I peeled one from a ranger gasket set and wow! It's totally different and looks like you could easily get it torqued evenly and quickly the first time because of the little metal inserts where the bolt holes are. Another vote for rubber.
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods:
Esslinger Prepped head, AiResearch T-3, 3.73 gears, Schneider custom grind cam, chromed rims, dynomax on the duals, and last but not least... new interior
AIM - Shizniblit
Jason Schaffer
Mods: 3.73 Gears
Finally getting it back together.
motormenace
Timonium, MD
the rubber one from ford (or comprable) works for me. i second the "cork shouldn't even be used on wine bottles. [Image: biggrin.gif]
69 mustang coupe (next project)
86 turbo coupe (it's fun beating a honda...with something twice it's size!)
86 SVO (it's amazing what people can screw up)
90 mustang GT (project scratch and dent)
...i'd rather be trolling...
86 turbo coupe (14.12 at 15 psi. sleeper) *gone*
...so you have a V8...isn't that cute...
