ILoveMyTC
May 2001
Delaware, Oh.
I just got my cyl head back from the machine shop after being resurfaced. Is it ok to paint it with some high temp engine paint to keep it protected from rust and such? And if so, should I mask off the gasket areas for the intake and exhaust, or is ok for those surfaces to be painted?
Thanks alot!
Nick Johnson
87'TC- Runs perfect...not even an oil leak!
88'TC- Distributor gear sitting in the oil pan in pieces
Nick Johnson
88'TC
97'LX
i would not paint the gasket surfaces. you want those as clean as possible when you start to assemble. i suggest you mask off the gasket surfaces, wipe down with MEK, alcohol or acetone prior to painting to remove any oil on the surface. lowes or home depot has acetone or alcohol available for very cheap.
Except for around the thermostate housing and above the exhaust manifold, there is very little of the head that is visible once everything is installed. I din't bother on mine. It's OK to paint it as VR22 described.
88 TC X 2, 86 SVO, Main TC with K&N, 3"DP to 2.5"duals through Dynamax, Ric valve at 17+ and disconnected KS.
Elite Bodega 16" chrome wheels. Autometer pod w/ A/F and Vac/boost gauges.140 mph Motorsports Speedo New engine: Total Seal rings and TRW pistons, ported and polished head w/ cc'd chambers,1.59"exhausts, SS valves, gutted upper, knife edged lower, A-230 cam, Race Engineering Adj Cam Sprocket, Crowlers, ARP head studs, and rod bolts. Walbro 255 HP pump and Kirban adj FPR, T-3. Centerforce II, KB subs and jack rails.
