The Rusty Chicken
Nov 2011
Cuyahoga Falls, Ohio
My '88 TC is slinging more oil from the rear main seal than I care to support any longer at $4/qt. I plan to pull the motor and replace the seal. That leads to the question of what else I should do while it is out and easily torn down. She has 133k on the clock and I am unaware of whether or not the motor has even been out. She is my daily winter driver, runs fine, and the turbo is happy to push 15-18 PSI on call. I am not overly concerned with making more power, I just want to insure reliability. My initial thought is to replace at least most of the gaskets, and any lines or hoses that look too long in the tooth. Any other suggestions?
Chris L. Klein
'72 Chevy Malibu
'88 TC
'92 Chevy Corvette
'08 Chevy Silverado
'08 Buell 1125R
joejo
Jun 2011
western pa
why not just pull the tranny and replace it? it would be easier. unless you want to do an oil pan while your at it. i wouldn't replace anything that wasn't leaking. also if you replace any gaskets please refrain from using silicone. i just rebuilt my motor that was suppose to only have 7k on the clock and every darn gasket surface was gooed with the red crap, even the oil pump.
88 tc
t3/4 50 trim stage 2 .48, bo 1.5 cam, lightly ported e6,stinger 3 inch ex., mild intake porting, basic cone filter, kirban, new motor (factory rods, .020 cp pistons, stock head specs).coolingmist injection, esslinger cam pulley.
I agree. If compression and leak down are good, try pulling the trans and replacing the rear main seal. It's a one piece unit.
The Rusty Chicken
Nov 2011
Thank you for your input. The more I thought about it, the more I was thinking along the same lines. If it ain't broke, don't fix it.
Chris L. Klein
'72 Chevy Malibu
'88 TC
'92 Chevy Corvette
'08 Chevy Silverado
'08 Buell 1125R
