Are Ford TFI modules interchangeable?
segfaultxr7 Offline
I'm having a problem that might be TFI-related. The thread is <a href="http://www2.turboford.org/nato/ubb/Forum1/HTML/001557.html">here</a>.
I can swipe an ignition module from my dad's broken 90 3.8 Sable, or borrow it out of his 90 2.9 Ranger or my 93 3.8 Cougar. Are they engine-specific or anything, or should I just be able to plug one of those in and see if it fixes my problem?
88 TC 5-speed
segfaultxr7 Offline
BTW--I looked up the part numbers for the TFI modules for the Fords I mentioned on wrenchead.com and they are slightly different. But that could be because of a mounting bracket or something too. I'm going to try the Sable's ignition coil tomorrow, I know it's good and is compatible.
88 TC 5-speed
turbobird Offline
yes, you can use the modules,what you should do is try and use the heat sink mount off the newer cars.
Jerry Rutten
88'Turbocoupe
Jerry R.
88'Turbocoupe
