I noticed in your video when the car was running BAD that the Tach was pulsing when bucking. I would think that may be the TFI breaking down. I would replace it along with the PIP. Your problem seems to be Ignition. One other possible cause could be a ripped hose in the tank and its bypassing pressure. Have you had the tank down and inspected the sock and fuel line. Just a THOUGHT!!!
Thill Seeker
Feb 2006
Bear, DE
Paul and B, I appreciate the help. I'm just gonna try swapping in a known good dizzy with a good TFI and PIP and see what happenes.
I hope that's it.
-'91 Mustang w/ '88 TC motor... The daily
-'88 Mustang w/ T-70'd 5.0... The race car
turbocoupes
Jul 2003
Aberdeen,Maryland
If it has an EGR valve...try disconnecting it... drive...and see what happens.
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Thill Seeker
Feb 2006
Bear, DE
So swapped the dizzy with a known good dizzy and no good. I also made a EGR delete out of some mild steel I had laying around since I found out the EGR was leaking exhaust (unmetered air) into the intake.
Car still doesn't want to idle correctly and is missing/bucking/stumbling still.
RDOG
Ontario. California U.S.A.
Take a pair of vice grips and squeeze the BPV hose closed. See if it runs better that way. You may have a bad BPV.
I would like to see some pics by the BPV, VAM hose, and recirculation tubing.
turbocoupes
Jul 2003
Aberdeen,Maryland
Did a search (bucking and stalling) and came up with these... Ignition switch, orange ground wire at turbo.
Thill Seeker
Feb 2006
Bear, DE
Alright garry, I'll look for the ground (almost sure I saw it too). I'll grab a ignition switch from work tomorrow (also going to get a ECT sensor, just to see if that's a problem too).
I also made another video...
http://s9.photobucket.com/albums/a87/pay...f6ef4a.mp4
I'm almost ready to call someone and have them come fix it, I'm to the point where I NEED a car.
-Mike
Thill Seeker
Feb 2006
Bear, DE
Will try that tomorrow (squeezing it closed). In the mean time here's some pics, you can see the piping setup in them.
http://i9.photobucket.com/albums/a87/pay...G_0516.jpg
http://i9.photobucket.com/albums/a87/pay...G_0517.jpg
http://i9.photobucket.com/albums/a87/pay...G_0518.jpg
Not B Anymore
Nokesville, VA, USA
Dude... if that's a Bosch bypass valve, which is what it looks like, it's in backwards. It looks exactly like the one in my wife's bug. Whether or not that makes a difference with that particular valve I don't know, but I would think that it would.
Brian Leavitt
Not B Anymore
Nokesville, VA, USA
Here's the valve in my wife's car. The large blue hose is the intake hose. Smaller black hose comes from the IC piping.
http://i798.photobucket.com/albums/yy270...G_2064.jpg
http://i798.photobucket.com/albums/yy270...G_2065.jpg
Brian Leavitt
