Matt S
Mountlake Terrace, WA
I have an aftermarket pump, ARG? I can't recall the manufacturer as it's been about 3 or 4 years since I did it. But the pump is really noisy when cold. I've bled it a few times and it always whines really loud unless the steering is moved for the first 15 minutes of running and then it quiets down. This thing was expensive. Is it going bad?
Sold it  *
junkedturbo
Apr 2008
Batavia IL
If its whining when cold thats a good sign of the pump going bad
Have you checked the fluid level for the steering pump :confused:
Protouring442
Jun 2009
Lenoir City, TN
Definitely check the level! PS fluid has a high rate of expansion, and if a little low when warm, can be low enoug when cold to allow air to get into he system and cause a whine.
Shiny Side Up!
Bill
Wait, where does this go?
Matt S
Yeah there's fluid in there.It's been bled and everything. I guess it's bad
Sold it  *
tr_guy79
Jan 2004
SE PA (DELCO), USA
Matt,
Mine has whined (whound??? lol) when cold since I bought it over 10 years ago... Not saying this is normal, but I will say that EVERY 80's ford vehicle I have/do own (84 LTD, 87 Stang, 87 TC, 89 f-150) has had at a least a slight whine to the power steering...
-Shane
