#11 |
Just remove the universal joints and the entire yoke will come off.
The joints can be removed with a 6" (pref. 8") c-clamp, a pair of needle noise pliers, and two sockets (one a bit smaller than the end caps and one larger than the opening of the yoke's cap openings).
It helps to relieve tension after every turn of the c-clamp by striking the c-clamp with a hammer. Also oil the clamp up really good before doing this, and spray some PB. Its also a great time for new u-joints.
Also, be sure to mark which way the u-joints came off of the DS so you can put them back on the way they came off.
Ryan Harris
1988 TC 5 speed, all options including sunroof. Currently installing: Walbro 255 LPH HP, Star stage III, Kirban AFPR, 3" DP to 2.5" duals, bypassed cat, Magnaflow mufflers
Ryan Harris
'88 TC Walbro 255HP, Stinger FMIC, PIT BOV, Pro 5.0, Kirban, RR cam, FRPP strut tower brace, T3
