natmac3
Aberdeen, MD
Nothing but personal preference. Using a dummy tfi as an "adapter" keeps the dizzy sealed up against the elements.
1987tc
TurboCoupe50
Chesapeake, Va
natmac3 Wrote:Nothing but personal preference. Using a dummy tfi as an "adapter" keeps the dizzy sealed up against the elements.
A bead of RTV across the bottom of dist housing will do same...
Not B Anymore
Nokesville, VA, USA
TurboCoupe50 Wrote:A bead of RTV across the bottom of dist housing will do same...
But then you can't tell people you have the "Dual TFI Mod".
Brian Leavitt
