unclefalter
Sep 2004
Squamish, BC Canada
Hi there,
I need some input on my exhaust, which is being done this week. I have a mechanic I know doing custom work for me on this, and what he's come up with is basically as follows:
2.5" downpipe, split to two mufflers, out as two tailpipes.
His rationale is the turbo on my car, being an IHI, only has 2.5" anyway, so going to 3" doesn't do anything? Does this make sense? Also does having two mufflers make any sense at all from performance standpoint?
88 TC 5spd - Black/Raven
The advantage in going to a 3" dP is the pressure differential it contributes to. Pressure differential is what causes flow. Granted, it may not be as critical for an IHI, but when you get a taste of the performance potential, there might be a T3 (or bigger) down the road
unclefalter
Sep 2004
Squamish, BC Canada
Thanks Pete..
So does single/dual exhaust matter? And having two mufflers?
RMartin
May 2006
Laramie, WY
I have a question to build on this, as I consider my future exhaust.
a single 3" full exhaust is enough for a significant improvement, right? from what I understand going to a dual 2.5" is mainly for looks/sound?
Ryan H
Panama City, FL
In a nutshell:
The duals are certainly for looks, but as long as you have a 3" downpipe, you're not going to outflow either of said exhaust systems without extensive mods.
'88 TC Walbro 255HP, Stinger FMIC, PIT BOV, Pro 5.0, Kirban, RR cam, FRPP strut tower brace, T3
chickencoupe
Apr 2006
new franklin mo
i ran 3" from the downpipe to the muffler, then tapered down to 2.5" , simply because its very tight under the car. the 2.5" will go over the axle and to the bumper. I have read it makes no difference in performance going to smaller pipe after the muffler.
88 turbocoupe, charcoal, red. 255lph, stinger 3' exhaust, gillis valve, a-237, adj. cam pulley, spec 3 clutch.
