Backup Lamps + Switch - Printable Version +- North American Turbocoupe Organization (https://turbotbird.com) +-- Forum: General, Technical & Performance (https://turbotbird.com/forum-general-technical-performance) +--- Forum: General Discussion (https://turbotbird.com/forum-general-discussion) +--- Thread: Backup Lamps + Switch (/thread-backup-lamps-switch) |
Backup Lamps + Switch - Gregg - 05-26-2001 Go figure, I get the engine all sorted out, and I find something new. My backup lamps are ON all the time. I am assuming the switch or relay somewhere is stuck. I think it may be the switch, as the car was parked for a bit, and I had it in reverse when I park (Manual Transmission, 87 TC) I am looking in the manual for the switch, but it talkes about a Column Mounted switch, and then it talks about a 4 Speed, under the section for manual transmission. Can anyone offer any help on where this switch is located? Or why they would be ON all the time? RE: Backup Lamps + Switch - Pete D - 05-27-2001 It located on the friver's side of the tranny in the big (front) part of the case. It should unscrew from the case and will have a wiring harness going to it. P/N is 15520 ------------------ 88 TC X 2, 86 SVO, Main TC with K&N, 3"DP to 2.5"duals through Dynamax, Ric valve at 17+ and disconnected KS. Elite Bodega 16" chrome wheels. Autometer pod w/ A/F and Vac/boost gauges. New engine shortly, ported head and manifolds, polished and cc'd chambers, A-230 cam, Race Engineering Adj Cam Sprocket, Crowlers, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs and jack rails. [This message has been edited by Pete D (edited 05-27-2001).] RE: Backup Lamps + Switch - Gregg - 05-27-2001 Quote:Originally posted by Pete D: Thanks for the info Pete, but a guy over at TurboFord helped me out. Turns out the switch isn't bad, but the wires to it are frayed like hell. Gonna solder them and see if that helps, and if not, gonna pull the plug.. Thanks htough! RE: Backup Lamps + Switch - Gregg - 05-28-2001 Just wanted to let everyone know that I soldered the frayed wires, and everything is back in working order! |
